i flipped off quite a few motors, as if it does anything but make u feel better.
recently, i've found the basics giving me hell, point gap, plug gap, fouled plug, timing, clogged carb, etc.
if its hard to start then suspect low compression, most likely a clogged idle circuit, but a big air leak needs to be compensated with gas, choke richer conditions.
