> Wolf Wizard Wrote:
> Slapped a brand new outta the box phbg on I had for another build.
> Waaaaay better idle. Carb gremlin for sure
I know it sounds redundant, but I cleaned my mikuni out several times before I found out that the idle jet I had in it was closed up. Not sure how it happen but I triple checked myself on things and saw the blockage only then. Put a new idle jet in and started right up.
Sometimes that third cleaning is what is needed.
Clad you had a spare carb to get it going. Maybe take the idle jet from that carb and put it in the other one to see if it works.
