> coby graham Wrote:
> No because with the lever disengaged both sides are free with it engaged
> only on side of the crank seems to be spinning
So the left side will spin without engaging the crank if you're not pedalling fast enough. Hold down the compression release on the right hand side and pedal hard, or push it which is probably easier. If you feel the motor engage and the right side still doesn't spin you might need a new crank
