honda pc50
Hi, after I cleaned the carb on my pc 50. When I started the engine, it automatically rev to the max and the back wheel was spinning so fast. Thank you for you input.
Re: honda pc50
Sounds like maybe you have a classic air leak . :(
Re: honda pc50
You could also not have the throttle cable seated correctly.-check this.
Also check for air leaks as mentioned above.
Re: honda pc50
I checked the throttle cable it was fine. I will check the for the air leak. don't know if the compression lever has any thing to do with it.
Re: honda pc50
thanks I'll do that
