Motorbecane v50
George taylor /
How do u get the motor mounts off I just can't get them out (edited)
Re: Motorbecane v50
Moped Lar (OFMC) /
There’s a tutorial in the wiki on how to remove them. You need a special tool to do it, but luckily you can make your own from readily available hardware.
Re: Motorbecane v50
The whole shebang including the metal outer is pressed into the frame via friction. You need to make a puller. A socket the fits over the donut, and a smaller one on that butts up against the mount on the other side. Run a piece of threaded rod or a long bolt threw the bigger socket, the mount, and finally the smaller socket. Tightening will pull the mount out of the frame into the larger socket. Reverse to put in the new mounts.
Re: Motorbecane v50
You can either buy a puller tool (treatland sells one) or go to your local hardware and get the parts to make a puller. There is a tutorial on the wiki, here https://www.mopedarmy.com/wiki/Motor_mount_bushing_removal
Takes a lot of force to get them out. You can use the puller to install the new motor mount brushings.
Re: Motorbecane v50
hold on a v50 may be different.
Re: Motorbecane v50
Poor audio but hopefully usable advice
(edited)
Re: Motorbecane v50
Don’t underestimate the difficulty of getting the mounts out of your frame, especially if you’re like me and trying to preserve original paint. With the tool or socket resting on the perimeter of the frame bracket, I wanted something between the big socket and the frame. I made a plastic washer to avoid paint damage. That complicates things, though, for putting a ton of torque on the puller. I bet the Treats puller has fine threads or something to increase pushing power. My homemade puller using a long bolt didn’t work. After you get yours out, post again here to share what worked.
Re: Motorbecane v50
If you are trying to preserve the paint you can always try to pull the old silent block towards the inside rather than the outside. Then the socket you are pulling into might mar the paint a little but not noticable like the face of the bushing land.
Re: Motorbecane v50
Alan Jackson /
just gonna attempt mine now after watching that
cheers rebel
Re: Motorbecane v50
George taylor /
No I got all that done but it won't start I pedal n the piston don't move n it is not in bike mode
