Re: Puch Maxi Wire Diagram
Follows
Just guessing your definition of clean is a little different .
I can't recall seeing a motor as filthy as yours .
grimy to say the least
I forgot cleaning in the bottom, i turned opside and i just saw this dirt, working on it.
I sprayed it with compression air before from top, i was surprise when i saw this, but i think many dirt was pushed down, it was the first time that i saw it upside down. Yes this moped was very dirty and is being dificult to clean because is to stuked... i dont know if i can use many water or any kind of cleaning liquid.. This moped was not mine, i dont know his history, i dont know wy is it like this. Just trying to get it work. . As you can understand all this is new to me, so im learning with every step. But the main goal of this photos was to show it inside... its possible to take any conclusion about cilinder condition? (edited)
How is the compression ? I'd check that first .
Can't really tell much through exhaust port .
Pull the head and have a look .
I couldnt pull the head, screws are bery stuck with rust. Any idea how to remove rusty screws?
Maybe a bit of heat and /or a good penetrating oil .
Its done! With a very good oil for rust. Also invested in new tools.
Lools to bad right?
It looks pretty good , as long as compression is good .
What are the compression readings ?
I dont have an compression reader... i cant find were to buy one localy.
Maybe an auto parts store ?
Make sure it has the proper thread to fit your head . (edited)
One thing, with engine like this im seeing the piston. Wen i roll the pedals constantly wasnt suposte to the piston went in and out also ?
Pedaling turns the rear wheel, which turns the front sprocket, which turns the main gear, which turns the clutch bell. It won't move the piston unless you're also engaging the starter clutch, which will rotate the crank.
The piston rings look very loosem its normal or have to be replaced?
Normal. And very good looking too!
