HONDA HOBBIT Rebuild Problems
Hayden B /
Gentlemen so I went down the Hobbit hole and decided to rebuild my entire engine meticulously since I lost compression and wanted to put on some “Go Fast” parts, here are the following that was bought and Built.
*70CC DR KIT
https://www.treatland.tv/honda-hobbit-pa50-moped-DR-46mm-70cc-cylinder-kit-p/honda-hobbit-dr-70cc-kit.htm
*Stock Hobbit Head
* Treatland Stuffy Racing crank with New Bearing and seals
*Boyesen Reed Valves from Treatland For Modified Mopeds https://www.treatland.tv/honda-hobbit-pa50-boyesen-power-reed-p/boyesen-honda-hobbit-reeds-mod.htm
* Brand New Hobbit Clone 16mmish Carb from Treatland
* Brand new gasket set all the way around for crankcase, intake, exhaust, head
(DR kit came with 70CC head gasket )
*New Woodruff key for Stator
* PROMA Exhaust pipe
****PROBLEM****
I got everything buttoned up and verified my spark, I went to do a compression test on my Cornwell Compression Tool before my first initial start. I was pushing about 65PSI, which I figured was just LOW because the New Rings take some time to be seated, so I tried to start it and Nothing I tried over and over to start it again and nothing.
I then maybe thought that since my compression is a little low that I’d remove the Stock gasket between the Stock hobbit head and the New DR cylinder kit, I did a compression test with no Top gasket and it went up to 75psi so I again attempted to start it with no Success
I removed the spark plug and it seems to be dry as if im not getting any fuel, which has me concerned thinking that my compression might not be high enough or I might have a air leak that I am not able to pull fuel through the float bowl into the actual cylinder to be ignited.
Any help is appreciated, nothing more disappointing then spending hours and money with the shiny new parts just for it not run lol.
  HONDA HOBBIT Rebuild ProblemsTopic by: Hayden B Hayden B 12/05/20 07:36PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: pat splat pat splat 12/05/20 09:14PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Hayden B Hayden B 12/05/20 09:36PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Hayden B Hayden B 12/06/20 02:21PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Dirty30 Dillon Dirty30 Dillon 12/06/20 02:28PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Hayden B Hayden B 12/06/20 04:01PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Hayden B Hayden B 12/06/20 09:54PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Happy Pancake Happy Pancake 12/07/20 06:47AM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Hayden B Hayden B 12/07/20 01:54PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: cheetahchrome . cheetahchrome . 12/09/20 10:10AM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Happy Pancake Happy Pancake 12/09/20 03:31PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Hayden B Hayden B 12/27/20 02:19PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Happy Pancake Happy Pancake 12/06/20 04:11PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Stephen Keller Stephen Keller 12/05/20 09:15PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 12/05/20 09:49PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Aaron Blair Aaron Blair 12/05/20 11:33PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Happy Pancake Happy Pancake 12/06/20 12:31PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: cheetahchrome . cheetahchrome . 12/07/20 10:22AM
  Re: HONDA HOBBIT Rebuild ProblemsRe: JBOT Admin JBOT Admin 12/20/20 11:09AM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Brent Bhuiyan Brent Bhuiyan 12/31/20 12:24PM
