Bought a new crank with the bearings and seals and installed them and just verified I have the arrow on the cylinder pointing down towards the floor towards the Exhaust port so I don’t think the piston is backwards
I do not believe the decomp is leaking what would be the best way to test that? Shouldn’t around 75psi be enough to at least pull fuel into the cylinder through the carb? (edited)
