***Update***
I Put on the original reeds and did a compression test again before trying to start it, Im right at about 80PSI WITH wide open throttle,
I also grounded the plug against the head and verified I have spark jumping on the spark plug when I pedal. I then attempted to start it and nothing again.
Pulled the plug and it’s still Mostly DRY with the tiniest bit of gas on it.
