Re: HONDA HOBBIT Rebuild Problems
Hayden B /
Great advice!! Thank you Cheetah and Pancake!
When I get off work,
I will be putting the New stock Hobbit head gasket back on as recommended as I did not lap the head like you have pictured, even tho it seems fairly simple!
And I will recheck my Piston Ring gap as I do believe that may be my problem since I don’t remember actually setting the ring gap to a exact spec just eyed balled them and made sure the ring was on the right way with the Guide pin.
Quick question for ya cheetah I can see why the removal of the head gasket would cause a leak between the DR kit and the stock hobbit head because the surfaces aren’t sanded and exact to each other, but why does removal of the head gasket cause the compression to raise if a bigger air leak was introduced between the Two surfaces? Just curious but will definitely put the gasket back on as I can see that being a issue now.
  HONDA HOBBIT Rebuild ProblemsTopic by: Hayden B Hayden B 12/05/20 07:36PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: pat splat pat splat 12/05/20 09:14PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Hayden B Hayden B 12/05/20 09:36PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Hayden B Hayden B 12/06/20 02:21PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Dirty30 Dillon Dirty30 Dillon 12/06/20 02:28PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Hayden B Hayden B 12/06/20 04:01PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Hayden B Hayden B 12/06/20 09:54PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Happy Pancake Happy Pancake 12/07/20 06:47AM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Hayden B Hayden B 12/07/20 01:54PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: cheetahchrome . cheetahchrome . 12/09/20 10:10AM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Happy Pancake Happy Pancake 12/09/20 03:31PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Hayden B Hayden B 12/27/20 02:19PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Happy Pancake Happy Pancake 12/06/20 04:11PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Stephen Keller Stephen Keller 12/05/20 09:15PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 12/05/20 09:49PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Aaron Blair Aaron Blair 12/05/20 11:33PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Happy Pancake Happy Pancake 12/06/20 12:31PM
  Re: HONDA HOBBIT Rebuild ProblemsRe: cheetahchrome . cheetahchrome . 12/07/20 10:22AM
  Re: HONDA HOBBIT Rebuild ProblemsRe: JBOT Admin JBOT Admin 12/20/20 11:09AM
  Re: HONDA HOBBIT Rebuild ProblemsRe: Brent Bhuiyan Brent Bhuiyan 12/31/20 12:24PM
