With the CDI wired up, remove the one wire going to the HT external ignition coil's positive connection. Remove the spark plug. Set a multi meter to AC VOLTS, 200 scale. Hook red lead to HT coils lead and black to a good frame ground. Crank the engine over and you should see ac volts.
Re: A35 CDI woes and troubles.
Subject | Written By | Posted |
A35 CDI woes and troubles.Topic by: Andrew Wrase | Andrew Wrase | 12/15/20 09:05PM |
Re: A35 CDI woes and troubles.Re: Tweaker trash | Tweaker trash | 12/16/20 03:26AM |
Re: A35 CDI woes and troubles.Re: ♣Slew Foot♣ | ♣Slew Foot♣ | 12/16/20 05:00AM |
Re: A35 CDI woes and troubles.Re: Andrew Wrase | Andrew Wrase | 12/16/20 09:18AM |
Re: A35 CDI woes and troubles.Re: Dan Pasanen | Dan Pasanen | 12/16/20 09:26AM |
Re: A35 CDI woes and troubles.Re: P D | P D | 12/16/20 10:40AM |
Re: A35 CDI woes and troubles.Re: Mark Alan | Mark Alan | 12/17/20 12:58PM |
Re: A35 CDI woes and troubles.Re: Graham Motzing | Graham Motzing | 12/18/20 02:40PM |
Re: A35 CDI woes and troubles.Re: Brian F | Brian F | 12/18/20 08:28PM |
Re: A35 CDI woes and troubles.Re: ♣Slew Foot♣ | ♣Slew Foot♣ | 12/19/20 08:21AM |
Re: A35 CDI woes and troubles.Re: Richard Eberline | Richard Eberline | 12/19/20 08:47AM |
Re: A35 CDI woes and troubles.Re: Andrew Wrase | Andrew Wrase | 01/02/21 01:23AM |
