Yeah rewind or if you wanna fix it for good the le partie: https://www.treatland.tv/peugeot-CDI-p/peugeot-cdi-after-partie.htm . Just be sure to replace the hardware in the stator with these: https://www.treatland.tv/peugeot-CDI-ignition-after-partie-ALLEN-bolt-set-p/peugeot-partie-allen-bolts.htm and red loctite em, buy this flywheel nut: https://www.treatland.tv/10mm-axle-nut-p/10mm-axle-nut-peugeot.htm and this puller: https://www.treatland.tv/19mm-x-1mm-flywheel-magneto-puller-p/19mm-flywheel-puller.htm . You can also lap the flywheel to the crank for a tighter fit, and put some loctite in the taper so that your timing don't slip as easy.
Re: Peugeot 103 weak spark
Subject | Written By | Posted |
Peugeot 103 weak sparkTopic by: Jim Blower | Jim Blower | 12/21/20 03:20PM |
Re: Peugeot 103 weak sparkRe: pat splat | pat splat | 12/22/20 01:42AM |
Re: Peugeot 103 weak sparkRe: Graham Motzing | Graham Motzing | 12/30/20 01:57PM |
Re: Peugeot 103 weak sparkRe: iskra chornia | iskra chornia | 01/01/21 08:35PM |
Re: Peugeot 103 weak sparkRe: pat splat | pat splat | 01/01/21 10:27PM |
Re: Peugeot 103 weak sparkRe: Downhill Harvey (OFMC) | Downhill Harvey (OFMC) | 01/02/21 01:42PM |
