Peugeot 103 weak spark
We to the moped world but not afraid to get stuck in with a little guidance.
I have a 1979 Peugeot 103 LVS U2 that got to me as a non runner, the previous owner told me he could not get a spark. After reading a few blogs and internet searches I went to work but need more help.
Flywheel looks to be timed, mark is about 3/4” past HT cable at TDC
Points start to open when mark is at HT cable
I grounded the single black wire from the stator and spun the engine with an electric drill using the flywheel nut.
No spark from the spark plug, I removed the spark plug boot and bared the end of the HT lead and managed to get a very weak spark on the cylinder head.
My assumptions are the wiring is ok but one of the ignition components has broken down. Where do I start and how do I test them.
(I have not taken the flywheel off as I don’t have a puller but will get one if needed)
Re: Peugeot 103 weak spark
its a weak design, look up on myrons page on pug 103 ignaition troubles.
There is a tutorial in the wiki on how to rewind these, it's really easy and it works quite well, I've done several.
Yeah rewind or if you wanna fix it for good the le partie: https://www.treatland.tv/peugeot-CDI-p/peugeot-cdi-after-partie.htm . Just be sure to replace the hardware in the stator with these: https://www.treatland.tv/peugeot-CDI-ignition-after-partie-ALLEN-bolt-set-p/peugeot-partie-allen-bolts.htm and red loctite em, buy this flywheel nut: https://www.treatland.tv/10mm-axle-nut-p/10mm-axle-nut-peugeot.htm and this puller: https://www.treatland.tv/19mm-x-1mm-flywheel-magneto-puller-p/19mm-flywheel-puller.htm . You can also lap the flywheel to the crank for a tighter fit, and put some loctite in the taper so that your timing don't slip as easy.
the only bummer thing with th le patiebis that you have to redo your brake light circuit from NO to NC or visa versa.
Downhill Harvey (OFMC) /
