Re: Timing reference
jumpsuit steve /
something like this:
https://www.treatland.tv/buzzetti-micrometer-p/buzzetti-ignition-micrometer.htm
it acts as a LIGHT piston stop to come up against while locking rotor down, and finds tdc easily.
and/or find a good way to lock the clutch bell, or otherwise work the other side of the crank so nothing budges when you put the rotor on.
timing light is a great tool too, shows how accurate your process is, and is a quick easy way to check things out.
