Well, I haven't had a chance to check out everything, but:
Oil level indicator light does not go out (even when I manually raise the sensor).
Turn signals don't seem to want to work very well.
Rear light is out now - no running or brake/stop light.
Oil indicator was not coming on at first so I checked sensor resistance per manual (pg 13-17). It read bad so swapped in a different sensor (which read resistance at both down and up positions, although not as much as manual says in up position. Manual mentions to operate the turn signals and also says to check for loose connections, so I figure that may be causing my issues - just haven't had a chance to go through connections all around the bike yet nor check to see if brake/stop light is blown.
A funny thing about this bike - as I said it is labeled as an NU50 and cam with a smaller battery and case, but the terminal ends had the rectangular connector like on the NU50M, but unlike the NU50M it doesn't have the extra pink wire in the tail bundle for the resistor (pg 16-2) - instead it has that extra brown wire which I mentioned earlier.
So, I'm confused, but will carry on trying to figure this out. One more thing - I confess to really not knowing my way around a multi-meter too well - just kind of learning.
Thanks in advance for any suggestions.
Joe
