Re: Replaced condenser on Bravo, now it won't run
Aaron Blair /
He means did you get the new condenser too hot when you soldered it in? Get em' too hot and you can kill them from the get go.
My guess is the simplest. Did you wire it in correctly?
Clean the points? Did you screw somthing up whilst cleaning the carb? Accendentally ground the kill wire?
Could be alotta things. Post a pic of your new condenser install.
