Re: Replaced condenser on Bravo, now it won't run
Pushrod Fifty /
Try a new plug, it coyld be fouled, make sure the cap is screwed good into the plug wire, and check for spark against the head. If you have to open it up again, make sure the condenser body is grounded, your points are clean with no oily residue, set and timed. Wires not grounding out from abrasion onto the flywheel, and external wiring clean and well connected.
