Treat's $70 Motobecane stock variator/clutch replacement ?
Marty White /
What do I need to do to install this on my bike-this bike was missing everything-I bought the 2 shims and circlips-special extra small snap ring pliers ? It doesn't have the grease fitting with it-size ? I take it the bearing already comes in there because it looks like everything is pre greased ? I've read it needs tightened up-torque specs ? Do I have to regrease by the fitting once everything is together-looks like the 3 ball bearings are dry ? Thanks Marty
