Just picked up a motron that has, at a minimum, a destroyed rear wheel bearing. What exactly do I need to order? Can’t compare to the old....just bits inside the brake hub. I see there are sealed bearing conversion kits, I’m not opposed to going that route, but also not opposed to just replacing what was there.
16” grimeca mag wheels.
Found a wiki page, but apparently it was specific to the 17”?
Yes, the measurements don’t jive...axle bigger than inner bearing diameter??? Trying to hold tablet, calipers, and snap the pic
