Re: Grimeca wheel bearings
Skip Allen /
> Nick MBC Wrote:
> I'm confused... on the axle you posted there's a loose bearing crown but
> the wheel bearings pictured in the wheel are sealed bearings?
Yes, I was a bit confused too. Bearing cups on both sides, sealed (open) bearing on the sprocket side and I have no idea what on brake side...just bits and shavings now. There were loose bearing crowns on both sides. Maybe that’s why it went out??
Ordered a 12mm axle, regular and thin nuts, and some sealed bearings. Hopefully I have no problems doing a sealed bearing conversion. Wiki articles look easy enough.
