Is this a possible mating?
I'm not sure the offspring would be viable
Like, the basic stock springer targar forks? The ones that are hyper prone to bending?
They don't/won't simply bolt on. The steer tube is too short on the Tomos frames. You're better off just putting on bravo/grande forks for the same effect and not having to do anything besides swap some bearing races.
Any fancy bicycle shop that does forks will have a facet/reamer tool for 25.5mm that they can remove some of the head tube of your frame. Then all you have to do is buy a set of Vespa headset and puch headset stuff and make some spacers maybe. Not hard but if you botch it, the bike is ruined.
tomos forks blow, I have so many and they're all trash
These are pretty https://www.mopedarmy.com/forums/read.php?2,4438736
Agreed. They will bend stopping too hard. Ha!
