Not idoling later on
So my 1980 garelli sport it will run fine for the first 15,20 minutes but after that it will not idol it will just shut off and wont start again until i let it sit for 30 minutes, anyone know what the problem is or how to fix it?
Re: Not idoling later on
Replace the condenser .
Richard Eberline /
Taillight wire is grounding out.
Dirty30 Dillon /
100%.
A quick search would have ruled this out very quickly.
where is the condenser
On the stator , under the flywheel .
Ok cool thanks
Be nice to your idol and it will then idle.
Heh heh!!
might be a swollen clutch oh its a garelli and the rubber clutch never swells when hot and never messes up your idle after 15 mins or so, just keep moving and dont stop till u get to your destination.
so i want to put it in the same place as the old one. Does it just bolt on?
> on?
For more reasons than one , an externally mounted condenser is best .
Here's a explanation of the procedure . It says for Puch , but it pertains to all points systems , but for the color of the wires .
https://mopedarmy.com/wiki/Install_an_external_condensor_on_a_Puch
And , another condenser may or may not mount exactly the same as the original .
where should i mount it
A lot of guys attach it to one of the ignition coil mount bolts/screws and attach the pigtail to the coil feed from the magneto .
roots to wings /
Yup, go external. Just did this yesterday for my 45 year old condenser (stamped Germany). Started right up.
