Re: Motobecane 50V Hard Start - Starter Clutches?
Aaron Blair /
Welp you definitely have an ussue.. I had a similar problem with mine and came up with an emergency pull start...Get yourself a 4 foot strip of soft leather about an inch in width at one end that narrows into around 1/2 inch on the other. Spray some belt dressing on the rough side near the wide end and tie the narrow end to a dowel...Roll it up around the dowel and keep it in the toolbox. Wrap that thing around the flywheel tightly and give it a tank!
I've even used a standard leather belt with good results in a pinch, but the tacky belt dressing really helps...used it with my Magnum too after a broke my starter cable.
It'll stop you from getting stranded again
  Motobecane 50V Hard Start - Starter Clutches?Topic by: Ron Kujawa Ron Kujawa 01/09/21 09:27PM
  Re: Motobecane 50V Hard Start - Starter Clutches?Re: Richard Eberline Richard Eberline 01/10/21 09:10AM
  Re: Motobecane 50V Hard Start - Starter Clutches?Re: Richard Eberline Richard Eberline 01/10/21 09:29AM
  Re: Motobecane 50V Hard Start - Starter Clutches?Re: Ron Kujawa Ron Kujawa 01/10/21 03:13PM
  Re: Motobecane 50V Hard Start - Starter Clutches?Re: Ron Kujawa Ron Kujawa 01/14/21 09:47PM
  Re: Motobecane 50V Hard Start - Starter Clutches?Re: Aaron Blair Aaron Blair 01/14/21 11:09PM
  Re: Motobecane 50V Hard Start - Starter Clutches?Re: Ron Kujawa Ron Kujawa 01/15/21 07:27AM
  Re: Motobecane 50V Hard Start - Starter Clutches?Re: Aaron Blair Aaron Blair 01/17/21 03:55AM
  Re: Motobecane 50V Hard Start - Starter Clutches?Re: Ron Kujawa Ron Kujawa 01/17/21 04:12PM
  Re: Motobecane 50V Hard Start - Starter Clutches?Re: EH FCC of the QCB EH FCC of the QCB 01/15/21 10:53AM
  Re: Motobecane 50V Hard Start - Starter Clutches?Re: Ron Kujawa Ron Kujawa 01/15/21 10:57AM
  Re: Motobecane 50V Hard Start - Starter Clutches?Re: EH FCC of the QCB EH FCC of the QCB 01/15/21 11:33AM
  Re: Motobecane 50V Hard Start - Starter Clutches?Re: Ron Kujawa Ron Kujawa 01/15/21 03:04PM
  Re: Motobecane 50V Hard Start - Starter Clutches?Re: Ron Kujawa Ron Kujawa 01/18/21 06:32PM
  Re: Motobecane 50V Hard Start - Starter Clutches?Re: Marty White Marty White 01/21/21 03:23PM
  Re: Motobecane 50V Hard Start - Starter Clutches?Re: Marty White Marty White 01/21/21 03:43PM
