A35 airsal jetting advise needed
I have an a35 with airsal 44mm kit and forget jetting with sha 1412 anyone running a sha and have advise thanks?
Re: A35 airsal jetting advise needed
74 no air filter
do you have a pipe on there or just the stock pipe ?
to give u an idea...
one of mine has a 14/12, 44mm kit with an techno estoril pipe 62 jet
stock air box
runs like a champ
a temp gauge is a good idea
yes because dirt has a way of finding a carburetor. yes thanks guys. I'm looking at buying a temp gauge from treats.
the biturbo
What was wrong with old threads on your other account? You know the same jetting questions you have already asked
because I was running the 1414 sha for awhile until jet threads went bad so I put the 1412 back on and forgot the jetting for the carb.
thanks Garrett! I had forgotten what was needed. because I've been running a 1414 for so long. but it's down broken. so had to put the dinky sha back on until I get a 1515. I heard they are better than the others. if 1515 doesn't get it I'm going for it and putting the vm20 on it
biturbo pipe . 44mm a35 head .
