Re: Flywheel nut?
Moped Lar (OFMC) /
Common issue caused by folks too cheap to buy the proper puller.
> Deron Miller Wrote:
> OK, I got a idea. The previous person that worked on the bike, tried to
> pull the flywheel with a two prong puller and was unsuccessful. He put a
> a lot of force on it, as the flywheel, where he grabbed it with the two
> prongs was bent, outwards. The threads look good, but the force of the
> center of the puller, might have belled out the starting end of the
> threads. I'm going to pick up a 8mm die and see if that can correct the
> belling of the end of the shaft.
