Re: HT ignition Coil repair
Aaron Blair /
Anything copper or zinc based woulda worked better. That will break from vibration, but the solder kinda flowed into the threads so it'll be intermittent break.i wouldn't be surprised if it isn't bonded at all and the joint is purely mechanical from the solder shrinking into the threads
....standard solder is not designed to work on ferrous metals. I use a special blend with a 400w hotdog iron to solder steel shield tabs to ground planes on old electronics....
