A3k Kickstart Mechanism
Del 80 /
That's the kickstart mechanism re-built, and the magneto cover installed......anyone know if there should be a gasket, or seal, between the cover and the crankcase ?.....can't see why there should be, as there is no oil in there.....it's just that there is about an 1/8" gap between the two surfaces, unless it's not sitting correctly.......
