Re: 1980 Honda Express Stator...how to test?
Jason Majernik /
Thank you! Appreciate the response I tested all the wires to the base plate and there was continuity to all the wires (0.7 resistance to the white wire). On the black and white wire, which goes to the points to the coil/condenser, there was continuity, but opening the points didn’t change that. I would have expected it to change based on the points opening and closing. Should I expect that?
Should I be testing from the ends of the yellow, white and black/white to the base plate? Based on what you’re saying, maybe I’m checking it wrong and I should test from where the yellow and white come out of the copper coils on the stator.
Clearly, I kinda suck at this so forgive me if these sounds like stupid questions.
