my 1980 honda express was running fine ! just letting it warm up one day it just died.
I checked for spark with plug grounded to head no spark, then with new plug ,to eliminate a fouled plug, still no spark.Put a jumper wire from coil black/white stripe
to engine black/white to bypass switches still no fire.Next i tested 3 wires that came out of engine case with a small light grounded to engine .white wire produced light ,yellow light produced light however the black/white stripe wire did not .i"m concluding my stator for ignition is bad. Myrons mopeds probably has part does anyone know of other sources also any know about converting to eliminate points
im see some kits for sale has any one tried that ?
