Re: Vespa Pinasco gear box assembly issues.
Daniel '' /
The shims are there for if your case is worn. Almost all of the gearboxes I have taken apart have like 3-4 shims, the one on the weird thrust washer on the input, maybe one on the inside of the input. And then the two around the output shaft/drive gear.
