Much straighter. Not perfect but if I move the sprocket over any more it is really floating off of the hub. This still has it over the lip just a smooch. It is within my acceptable tolerance so I'm gonna run with it.
The bigger issue right now is really that my bearing keep walking out of the hub, it pulls the other side in at the same time, as I have all the spacers in place inside the hub. I think there might be something off with the hubs allowing things to shift a little under load. Might need some new wheels.
