Re: Chain alignment
baird co /
Sealed bearings? Is there a ridge that the bearing sits on inside the hub? If there is, it's loose somehow. If there isn't, it needs one.
If. The bearings are just pressed in and there's nothing to stop them from going in deeper, the wheel will walk to one side or the other, which is not good.
