Re: Clutch Shimming Problems
Overpriced Parts /
Didn’t follow shim directions perfectly, You have too big of inner shim,
On Some stuffed aftermarket cranks I had to use a .6m on the inner shim
If you did it before the engine was put back together which is easier you could see how the old gear pattern meshed
