Re: Bent exhaust header
Rowan Vannier /
I sanded it down a bit to where it is almost completely flat. I used a feeler gauge and there is roughly 0.30 mm of a gap between my flat surface and the exhaust flange. I picked up the 50% crush gasket, so the minimal gap should not be a problem? Should I be worried about the flange getting too thin to the point where it would crack under high temps?
