3-- in the above photo, the right side shaft has a large double needle bearing that fits inside the mini output shaft. that same bearing will fit on the left side shaft, without it the left side gears dont fit on the shaft properly. is it safe to assume there are two of these and im missing the other?
4-- last question....what the fuck is this arm mechanism? whats its function and does it attach to anything internally?? (yes i know the bearing is supposed to be open, im leaving shield on for protec until its ready for assembly)
sorry i know this is a lot, but i appreciate any pointers!! or if you can link me to the correct engine manual as i could only find the one and its not right. thanks
