Re: new Tomos brakes from treatland not working
Jay Rivett /
Tomos uses an open ended cable and has a pinch bolt on the brake plate. T hff at allows you to pull all of the slack out of the line and push in the brake lever about 2/3 the way in. Then pinch the cable there. That will give you the proper tension. If you need additional adjustment after that it is the bolt at the brake hand lever.
