Honda PA50 - Jet Size 75? - Advice
W D /
Hi
My Camino has a stock Keihn carb with no mods.
Just taken off float bowl to check jet size as was just curious.
Looks like a stock Keihn main jet at size 75?
Bit difficult to see as the 5 has been chopped off.
Would everyone confirm that this is a size 75 main jet?
If I were get go up in size say 80 that would be a larger diameter hole and visa versa?
Reading up on here I don’t think this is what normally comes on the carb?
[quote]Carb[edit]
The PA50II carb has a 12mm venturi, versus a 10mm venturi of the PA50I version. It also has a #78 jet versus a #60. [A PA50II carb, reed block, and manifold on a PA50I engine will net you 5+MPH]
[/quote]
