Re: 1981 Hobbit Won't Stay Running
pat splat /
just look at your carb, theres a couple passages you can clean out using beake cleaner and pressurized air before attempting to remove carb. also you can drain your float bowl, theres another screw and you can clean your air filter if its there.
