Since the hi-torque has a cast iron bore you could probably hone it and run it as long as it doesn't have any deep scoring above the ports. That piston could be reused in a pinch as well, just knock down any high spots and clean up the ring lands so the rings spring freely. I'd go with some new rings though. That lower ring has a crazy amount of end gap somehow.
