Re: Replacement piston/ rings for maxi
P D /
> Saabsonettguy . Wrote:
> Since the hi-torque has a cast iron bore you could probably hone it and
> run it as long as it doesn't have any deep scoring above the ports. That
> piston could be reused in a pinch as well, just knock down any high
> spots and clean up the ring lands so the rings spring freely. I'd go
> with some new rings though. That lower ring has a crazy amount of end
> gap somehow.
Likely because the side not seen is free in the landing .
And , I'd simply clean that piston , smooth any high spots ; run a quick hone through the cylinder and run it .
The pistons in two of my bikes are in much worse shape than the very minor scoring I see on yours' . ;)
