Re: Vdo speedometer drive after sealed bearing conversion
Mike Boyd /
Yeah I don’t see why not if you’re careful. Basically try to replicate the notches in the loose bearing shield assembly pictured, but by removing material from the hub on either side of where the sealed bearing is pressed in. You will need to figure out the proper size shim to go in between the bearing and the Speedo drive in order for the drive to work smoothly and not bind, but that’s the case with all sealed front conversions anyway.
