I believe the wiki has a wiring diagram for these as well. The HT coils on these have been known to go out due to over heating with being inside the flywheel and covered. If you are feeling crafty you can get a 5 or 6 wire setup and a new exterior HT coil. Would cost a bit but makes the system easier to work on and less prone to failure.
