new stuffy za50 crank .010 out, big problems ahead?
Jesse Nordlander /
brand new stuffy za50, installed and noticed light binding rotating assembled clutch. mounted it in the vise and ran a dial indicator. noticed .010" runout on both sides. max runout is 180 degrees out from side to side.
Re: new stuffy za50 crank .010 out, big problems ahead?
How did you press the bearings on the crank? Did you support it from the center as to not stress the rod pin? Or did you just rest it on the opposite side and press it on?
