1978 blanco
First post here! Just picked up a blanco for cheap. Was seized up. I’ve pulled it apart and replaced the piston. Im fairly sure the size is correct on everything (38.8mm) yet it still won’t smoothly slide through the cylinder. I’ve honed the cylinder and still not had any luck. Looking for any insight!
Re: 1978 blanco
Moped Lar (OFMC) /
Did you put the rings on correctly?
Re: 1978 blanco
Yeah, like Lar is suggesting, this ain’t rocket surgery, but if you don’t do that top end right, might as well go buy a scooter. Go to the wiki and read up on gapping rings...100% essential
Re: 1978 blanco
Time to bust out the calupers.
