Re: Engine barely runs then backfires to a stop.
Papa _ /
When you say: “put everything back together” what did you do to prep the flywheel to mate to yhe crank after slipping the key?
No judgement. I did the same thing because the CDI flywheel just doesn’t fit right without lapping.
It will slip again if you didn’t do that.
