Re: Seized crank case screws
pat splat /
Totally possible if you didnt drill too deep. The heat from the weld helps loosen things up. What motor we talking about? Also if the bolt heads are gone whats holding you back from splitting the cases? A plumbing a block of wood and a hammer does wonders.
