I hooked the black wire from the stator to the coil and still no spark. What's next?
ground the frame to the swingarm
check if the black wire puts out volts, or without a meter just check if it sparks directly to the flywheel, like makes little sparks
clean the points, if it's points.
Thanks, I'll try that tomorrow,
I got it running. It was the plug wire.
