Derbi Hunter 70cc won't run correctly
hey guys i recently did a 70cc swap on my derbi hunter but I cant keep get it running correctly. during my first install of the kit i broke off a piece of the cylinder skirt but decided to install in anyway as it was only the very bottom part. I an it with the exhaust off which seemed to work fine the once I put the exhaust on and ran it for a longer period of time it got worse and worse until it could only idle and now sometimes it won't even do that. i think i might have an air leak in my cylinder. what do you guys think?
Re: Derbi Hunter 70cc won't run correctly
Is this bait?
Yeah you might have an airleak somewhere
Tune is probably off.
Start from scratch and check everything
Timing - jetting - gaskets - torque
Tweaker trash /
This is the second cast iron kit I seen out of the box with a broken skirt
todd amundson /
Stick your mouth over the pipe header and blow! If there’s any resistance the pipes clogged. Don’t fucking cheat and use an air gun. It’ll show a false negative. Stick your nasty mouth on the header and blow. I’m not fucking around.
I want to see a video of you doing that . LOL
You gotta set the piston at bottom dead center if you're doing this with the pipe mounted on the cylinder though, otherwise you'll be blowing against a wall essentially
