91' Suzuki shuttle fa50
I am new to the moped world. I recently acquired a 91 suzuki shuttle fa50. I was riding it the other day and it ran well for about 10 minutes....you saw on the speedometer the speed go down substantially..than all of a sudden dies...i started it back up and it ran a little bit then all of a sudden while holding throttle open..it dies again...it will start up but wont even give enough juice to turn the tire....i have cleaned the carb...and i have put new air filter on it....i changed the spark plug...i dont know what else the problem could be...i noticed there is no petcock on the bike...but i placed a shut off valve when i got the bike m ..please if anyone has info..please help...thank you
Re: 91' Suzuki shuttle fa50
Sounds like you seized it . Pull the top end off and post pics of the cylinder and the piston .
What oil are you running in the injection or premix ratio ?
This is what it looks like inside..i took the head off...fairly easy...now if it was seized would it kick over when i move the kick starter??...cause it moves easily when i push the kick starter...
Carboned piston top .
Next , pull the cylinder .
We need to see the piston skirts and the lower part of the cylinder .
Loosen the muffler mount bolt and then remove the mount bolts to the cylinder .
Reverse , when putting it back together .
You should remove the carbon from the piston ... ;)
Yea..its all black in there...when i put in new spark plug...ran one time n took it out and it was carboned...whats that mean?
Ok i see a lot of sludge inside it behind the cylinder
Nothing seems to be wrong with it other than it being dirty as hell
It soft seized .
I'd take any high spots off the piston skirts and lightly sand the cylinder to rid it of any aluminum deposits .
Clean the exhaust port .
Clean as much of that crud in the crank case out as possible . It should be real close to spotless .
Put it back together .
The muffler could likely use a clean-out. Remove the muffler . Fill it with oven cleaner and let it sit for a while . Rinse it out with a garden hose . Repeat and it should be good enough . You should be able to run a stiff wire ( maybe a straightened wire coat hanger ) through the tail piece , all the way to the front of the muffler can .
Ok i cleaned it and put it all together...and it started up after a few kicks...now its smoking like crazy...why is that? And how do i fix that?
Likely just too much oil or other residues that are getting burned off . Just run it for a while and see if it clears .
