Scooter id (Lifan?)
Chris Hastings /
I just got a scooter for $15!!!
No fairings. Lifan is embazoned on the motor.
Where do I find a VIN?
Thanks!!
c
Re: Scooter id (Lifan?)
Headtube maybe?
Eric Davenport /
Should be one on the frame under a cover on the floor.
Chris Hastings /
I found it, thanks!
It was folded under one of the frame tubes on the right side.
More questions... Any idea the model#? Engine size/model?
Thanks!
c
GY6 engine . CC should be legible on the cylinder . Usually at the bottom .
Says motorcycle on the tag so prolly a 150cc. Time for a motorcycle lisense
The 1P57QMJ motor is a slight variant of the 150cc 157QMJ on my scooter. Not sure what, if any, differences there are. Most 150cc GY6 parts should bolt right up.
This document tells you a bit about the VIN, and lists some possible model numbers, but unfortunately it doesn't provide a mapping between VIN & model: https://www.nhtsa.gov/es/filebrowser/download/243441
^it's the long case, fits bigger rear wheel, longer belt, but pretty much everything is generic gy6 150. The model doesnt matter at all, theyre entirely interchangeable even to the DMV folks. tell em its a TaoTao and badabing! it's now a taotao.
